Pls Help with Kef eggs
Discussion in 'Home Cinema Speakers' started by mahmudf, May 21, 2003.
  1. mahmudf
    mahmudf
    I've just bought the Kht 2005 and I'm having a problem with one of the eggs. I'm hearing a crackling sound from it and believe its definitley the speaker and not my connection because I've swapped it with one of the others and they seem fine. Another problem is that I cant get in touch the retailer www.go2camcorder.co.uk (ther're not answering any calls). I would'nt mind buying an extra one or selling the rest of the system separately then purchase the full set from some where else.
    any help would be gratefully appreciated.
    thanks
    Farrukh
  2. wookie
    wookie
    Have your speakers got serial numbers?
    If they have, KEF may take a look under warranty.
    If theyt have no serial numbers (like mine):confused:you are on your own unless you can get hold of gotocamcorderetc.con.
  3. sounddog
    sounddog
    Dec 11, 2002
    3,416
    107
    Leicestershire, UK
    +474
    If they are brand new then hastle KEF anyway ... they still have to honour warranty (IIRC) though not the extended warranty that KEF UK offer.
  4. mahmudf
    mahmudf
    Thanks for your help
    where is the serial number located, is it on the base of the speaker
