VeniceDAC
Ive got this Sannce CCTV (MOdel dn81q1T) for quite a while and I need to reset it up but I have forgotten the admin password.
I can login to the "user" (username) though and connect it to LAN also.
Apprecieate if you can provide workaround how to reset it to factory without password.
I've searched and SANNCE support asked to submit alot of information I dont have (i.e. order/invoice etc.) since this was purchased way back.
Thank you in advance.
Venice
Venice
