pls help, how to get rid of the multi symbol on my 11sr.
Discussion in 'AV Receivers & Amplifiers' started by oreoboy13, Aug 18, 2002.
  1. oreoboy13
    oreoboy13
    cant find it any where in the manual, and my gf managed to make it come on while i wasnt looking. Any help much appreicated
  2. eddiea
    eddiea
    Multi zone or Multi channel?
    where is it displaying, on the amps display or on the TV screen?
  3. Jase
    Jase
    Mar 16, 2001
    10,822
    United Kingdom
    +2,714
    Should be a Multizone button on the front of the amp or on the remote, pressing this should get rid of it. May be slightly different on the A11SR compared to my Denon.
  4. oreoboy13
    oreoboy13
    on the amp not the tv or remote. It just says MULTI , when i press the multi button is comes up with REC, and then back to MULTI with a subsquent press.
  5. Jase
    Jase
    Mar 16, 2001
    10,822
    United Kingdom
    +2,714
    When you press the Multi button try turning the Select knob on the front of the amp, does that cycle through any options?
