Plinius 8200P or Bryston 4BST
Discussion in 'AV Receivers & Amplifiers' started by Lowrider, Feb 19, 2002.
  1. Lowrider
    Lowrider
    I am bringing home a Plinius for a test drive, as I cannot do the same with the Bryston, does anyone think the second is worth 40% more, and why...
    Thanks,
  2. Lowrider
    Lowrider
    Well, the Plinius has better bass than the Rotel, but everything else is muffled... I guess I will go on and buy the Bryston blindly...
  3. Couch Potato
    Couch Potato
    Antonio,
    Difficult call with somebody else's budget however the Bryston's are significantly better than the Rotels, I like you have TAG/Rotel. I've demoed the Bryston and thought it was superb, slightly better than the TAG Amp (100x5, so not a direct comparison) It is an incredibly neutral amp and with your components should be a good match.
    Plus it's got a 20 year waranty :eek:
    Have fun:D
    Steve
    Dont forget to post your comments on the TAG site also and wind Glenn up!!!
  4. greeny
    greeny
    What am I missing here?? Is there only 3 manufacturers of Power amps??.
    You don't have to go for 5 amps in a box approach, you could use multiple stereo amps giving a much bigger choice.
    I'm not saying your choices aren't any good (I've not even heard them to be honest) but don't think its the only option.
  5. Lowrider
    Lowrider
    I already have a Rotel 3x200 for center and surrounds, and a stereo 2x200 for the fronts, the one I am replacing...
    For that stereo amp I have limited space in my rack, wich narrows a lot my choices...
    I do have a post in TAG´s forum, starts with "Price ratio"... ;)
  6. Couch Potato
    Couch Potato
    Hi Antonio,
    I've seen the TAG post, Dominic as usual makes sense!!
    There is little to choose they are both excellent, the obvious answer is the one that's no use..... use your own ears :(
    Steve
  7. Couch Potato
    Couch Potato
    Hi Antonio,
    Edit: Sorry just seen your reply!!
    Steve
  8. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Blush:blush:
  9. Lowrider
    Lowrider
    I just got a message from the local Bryston dealer offering to lend me a 4BST for testing... :D
  10. Couch Potato
    Couch Potato
    Then I guess the advice is..... use your own ears, backed up with a tape measure!!!:clown:
    Steve
  11. Lowrider
    Lowrider
    My setup has to be a feast for the eyes (mine and the wife´s), as well as for the ears...
    I will post my findings, thanks,
  12. Lowrider
    Lowrider
    Amasing power... deeper and more controlled bass, higher and clean as a whistle treble, clearer everything, you hear soft and loud toguether...
    More, there was a ringing when playing the Rotel very loud, that was fatiguing, it is gone with the Bryston...
    To sum it up, I upgraded almost everything since I bought my AV 9 months ago, last night the wife said that the only pieces that made a clear sound improvement where the new front speakers and this power, do I need to say more...
  13. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Welcome to the joys of low distortion amps.
  14. AV Geeza
    AV Geeza
    Oct 10, 2001
    397
    Londinium
    +3
    Antonio,
    Glad you like the Bryston! Ive had the 9B THX for a few weeks now & I think its amazing! :D
    IMO the TAG, Bryston combo cant be beat for sound quality & VFM.
    I know you upgraded your DVD to the Arcam FMJ, how much better than the DV88 is it and how good is it with CD's?
  15. Lowrider
    Lowrider
    FMJ DV27 versus Diva DV88:
    The image is much better, and I am not using progressive scan, (will when I upgrade to a plasma), specially the bright parts, is like comparing slides with photos...
    The sound is cleaner too, (I am using the TAG´s dacs), I noticed the DV88 was producing too much treble, after I upgraded the front speakers (didn´t notice with the previous, the tweeter was weaker), must have been more jitter...
    Anyway, I think it is worth by either sound or image alone, and it has progressive scan, only usable with plasma or projector until new generation HDTVs...
