Plextor r/rw probs???
Discussion in 'Desktop & Laptop Computers Forum' started by danny-p, Apr 21, 2003.
  1. danny-p
    danny-p
    Im using a plextor (plexwriter 24/10/40a) reader/writer to rip songs from cd's to my other computer as its not on the net using plextools supplied on winXP.
    The problem is, when the cd data is read and shows the tracks (1 to 19) on the screen if you right click say track 1 and select "play song1" at the start of the song is a loud buzz??
    I thought this was a slight conflict with win media player at first but when ripped/burnt the song the buzz is still there??
    Its nothing to do with the way the song starts off as i have tried ripping the same song from a different album and it worked fine (all originals btw).
    Hope anyone can help.........
    Danny-p
  2. danny-p
    danny-p
    ...........Just thought i'd add that 3+songs per album make this loud buzzing sound at the start of the song, so its not just a one off error.:confused:
