Question Plex not working on mobile data
REJI
I’ve set up a Plex server on a old Mac mini I have lying about (due to my main server not working for the time been)
ive no issues seeing watching movies on my home network but once out of the house the app can’t find my Mac server therefore no movies once back on the home network all fine
I’m not sure if this is the Mac or the router. If anyone has any ideas it would be much appreciated
Bigfingers
Have you forwarded the relevant port to access plex on your router? I would recommend manual rather than using DLNA.
REJI
[/QUOT
morning
I’m going to say no
If I change to manual am I required to input .
If so I wouldn’t know how to do it
Bigfingers
The machine you use as your server, needs to talk to clients outside of your home environment.
In order ro do this, you need to open a port. This is like an unlocked door that you can pass all the data through.
You need to open a port in your router to the IP address of the plex server, then enter the corresponding info into the set up page in your plex server, so it matches.
Then use an online checker, such as canyouseeme.org
REJI
I understand that bit and inside my router just not sure how to fill the details in
if port forwarding is the issue will talk to bt then they can talk me through it hopefully
REJI
Ok a step in the right direction
I have a green tick against remote Access
But now transcode issues on the app
do I alter on the app or the server ?
REJI
Ok turns I’m a absolute moron
turns out Plex won’t remote play or transcode if you don’t plug your hard drive into the pc correctly
@Bigfingers I thank you for your help and postings
I apologise for wasting your time in helping me
When it was something I should have checked from the start
Again thank you
Podcast: Reported HDMI 2.1 bugs, Audiolab Amp & LG LED Projector reviews + Best of the Month
