hockeyrulz
I'm looking for some help to solve my 4k streaming problems with Plex. I'm certain I have streamed them before in exactly the way I'm trying to now, but now it isn't working and keeps buffering all the time.
I can provide logs etc if needed but to me they don't say a whole lot. The computer I host my plex server on is nothing special and has a i5 8400T processor but the files i'm playing are not being transcoded so I don't think that matters.
When I'm playing one of the files which is HEVC 10, 80mbps bitrate I can see on the plex dashboard that it is using around 100mbps to send the stream onto my network, my router then says that this computers is only using around 10mbps.
The files are stored on a DLink 320L, which honestly is a bit of an older NAS drive, but it has Gigabit Ethernet and the CPU usage sits around 20% and the RAM is around 90% but it always is.
My router is an Asus RT-AX92U, the nas and plex server are both wired into one AX92U then I have another under my TV which is an LG 65C9PLA OLED with plex app installed. Everything is cabled with at least Cat5e.
I'm convinced its a Plex issue because I can play the files perfectly through VLC but if anyone can suggest anything I can try to get this working that would be great. Its also worth noting that I have some 4k videos that are 20mbps and other that are 50mbps and 80mbps, the higher the bitrate the more if buffers obviously but some of the 20mbps ones I have don't buffer at all. all files are mkv and I get the issues on every device I use to playback, desktop, phone, TV's.
