Pleeease help me connect Xbox360 to Virgin modem - problems with system update
richnemma
Hi all, can someone please help me with this before I go mad.
I bought an xbox360 yesterday, and have plugged it straight into my Virgin Modem (i.e. unplugged the PC). Before changing the plugs, I powered down the modem,and powered it up again afterwards.
When I clicked on check system settings, it passed every test until it got to "Xbox Live". It told me I had to download a system update, and if I didn't it couldn't continue.
I try to download the update, and am told "Can't download the update. Please test your connection in system network settings..." - which it passes with flying colours every time!
Can someone please please please give me some advice?!?!
Many thanks - you may just save me from insanity.
Scholes18
You're not doing anything wrong fella.
Its live thats kaput.You're pretty much knackered till its sorted unfortunately.
Have a butchers at www.xbox.com/support to see the "helpful" status info messages MS put up.
Uptill the last couple of weeks its been rock solid and i connect directly to the modem in the same way you do .
keep trying is all i can suggest. sooner or later it'll sort itself out.
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
