please tell me the name of this part?
samsimon1
hey, I got this "wall mount metal thing" from the back tv's panel - these are used to screw the screw to wall mount, Two of them broke - I need to buy, but cannot find the name for it...... thanks
paulyoung666
I doubt you’ll replace them easily to be honest , they look like a press fit , how did they come out ?
samsimon1
they didn't come out, The threads messed up - because of the bad screws..... thus I opened a panel, and these Threaded Blind Rivet Nut are just attached to the back tv's panel, and easily removed using pliers, you can easily replace them all...
samsimon1
these nuts not only for TVs they are used everywhere.... on almost anything, even walls or cabinets - also on many products that need to be mounted/walled.....
Ftorek
blind rivet nuts
even though the ones in the telly seems machined to slightly different spec... check the thread inside for size
f.
paulyoung666
there you go then , well at least it’s a start for you , I just wish you had given all the information you had in your first post ...
Podcast: Sony A90J Thoughts, madVR Processor & Sonus faber Lumina II Reviews + Movie & TV roundup
