nero0410
I would like to ask a question
I have bought an Xbox 360 (core), and I have a Panasonic AE200 Projector
I would like to know if my projector is HD or not?
I'm not sure as in the manual on the list of compatible signals it says HDTV60 and HDTV50 ( 1920 x 1080i ) using either VGA or YPbPr (component)
It also says that it does all the signals like 480p / 720p / 1080i
Does that mean that my projector is [/I]true HDTV compatible?
I would like to know as I would like to find out weather I should get a HD Component or just a normal one
tris
tris
