PLEASE! simple advice required - please reply!
Discussion in 'Home Cinema Speakers' started by sainthalo, Jan 6, 2003.
  1. Yamaha 220
    0 vote(s)
    0.0%
  2. seperate floorstanders, rears and centre
    4 vote(s)
    100.0%
  3. other (please post details)
    0 vote(s)
    0.0%
  1. sainthalo
    sainthalo
    One home cinema pc for everything (movies, tv, music). Will buy a seperate receiver (yamaha or marantz 4300 - up to £300).
    Now question is should i get speakers like missions floorstanders etc or just go for a package like the yamaha 220? which would be likely to sound better? is there much difference? videologic digitheatre level sound required as minimum spec.
    You can vote on the poll - Thanks, dont like to ask salesmen as often they lie (or dont know).:eek:
  2. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    you won't go wrong with either a yammy or marantz receiver at that price, as for speakers you don't have to have floorstanders up front, you also have the choice of a sat/sub combo or some bookshelf speakers on stands.
  3. Mitch2000
    Mitch2000
    Dec 28, 2001
    158
    16
    Kent
    The Yamaha 220 speakers are good for a start but the bug will get you and you'll be looking at something bigger and better soon as I did last year.
