Please recommend the most expensive/best 5 Metres Coxial Cable.
Bloodflowerz
Hi all :hiya: ,
I recently purchased the IXOS XHD608 Digital Coaxial cable which is 1 metre long.
However, after reorganizing my bedroom, I now need a 5 metre cable instead. IXOS don't do the 608 in 5 metres, so I was wondering what is the best, most expensive 5 metre cable I can purchase on planet Earth?
Surely, there must be others out there who had the same problem as me...
:thumbsup:
Cheerio!
Brogan
How much do you want to spend?
You can pay several hundred pounds for a 5m coax cable.
Or, if that's not expensive enough for you, I'll supply you with one for a measly £100K.
Alternatively, you could make one yourself using double shielded coax and 2 RCA/Phono connectors. Total cost should be less than £5.
Bloodflowerz
Good point. I am looking to spend around £50 /10m. I was actually looking at the IXOS Premium Quad:
http://www.futureshop.co.uk/ixos-premium-quad-shielded-digital-coaxial-audio-cable-custom-p-597.html
or QED Professional:
http://www.futureshop.co.uk/qed-professional-digital-coaxial-audio-cable-custom-length-p-562.html
I had no idea that you could get Coax cables for £100k! How many metres is that for?
D
Deleted member 30535
Don't equate cost with quality. You'd be hard pressed to find a better interconnect than one of those offered in the PowerBuys.
If you need some flexibility on your cable, then the Canare LV77S cable, although billed as a subwoofer cable, would be your best bet. The Belden digital coax interconnects based on the 1694A cable has a minimum bend radius of 7cm, which is not ideal for going around tight corners! But then I have not been able to confirm the LV77S radius, all I have heard is that it is more flexible than the Belden cable.
HTH
deaf cat
