Please recommend screen protector manufacturer
f6cvalkyrie
Are you using a screen protection on your LCD screen ?
Which brand ?
Are you happy with it ?
On E-bay, I could find many different makes for my Panasonic G1, but which one do YOU recommend ??
TIA
Rafael
f6cvalkyrie
Thanks for your recommendation, but I could not find my G1 in the model list from ZAGG. I'll leave them a note !
C U
Rafael
Oversleep
I find it cheaper to buy a larger size of screen protector and cut it down to the smaller size.... 17" is just under tenner on ebay....
Damien
Are they worth it? I mean has anyone experienced scratching them?
D
f6cvalkyrie
maybe not really scratching, but smearing certainly, and also, I do hope the protection might help to reduce reflections on the LCD screen ????
There's many models and makes on ebay, but I don't have a clue which one to choose :mad:
good night,
Rafael
waffley
good night,
Rafael
I was wondering too which make to use. I have purchased an expensive one, which began peeling off after 2 weeks and a cheap one which isn't quite large enough for my A300 although it was advertised as such. So any recommendations would be gratefully received
Marcia
