please recommend me a budget/compact/easy to use PC setup
Discussion in 'Desktop & Laptop Computers Forum' started by figoagogo, Jan 11, 2012.
  1. figoagogo
    figoagogo
    Mar 29, 2005
    8,182
    +579
    Can some please recommend me a budget/compact/easy to use PC setup. It is for my parents, currently they have tower + monitor (Win Vista), they want to replace this with a tidier solution:
    They like the "ALL-IN-ONE" types (i.e. a PC in a monitor) or possibly something like a "NET TOP" Acer Aspire Revo R3700 Nettop - Revo Nettops | Ebuyer.com this has no drive, which would be required).
    It does not need to be super powerful, just quick, reliable, tidy, easy to use, internet/out look will be its main use! In addition they do have a Sony Internet TV, and I would consider using it to strore and stream movies, the current PC will not do this!
    ALSO - the monitor they have is tiny so it would need to be part of a NET TOP package. Keyboard / Mouse not an problem, but they would need plenty of USB ports.
    Can anyone recommend something, say £350 budget, they would perhaps prefer a "real shop" PCWORLD/CURRYS but not afraid to try online like Amazon/E-buyer/Dell.
    I am so out of touch with this, I just run a bog standard laptop these days.
    Links would be nice - I just want to say look at this or that, then order it in for them!
