Please Recommend Good slim av receivers with canton CD 1 speakers
Discussion in 'AV Receivers & Amplifiers' started by supo, Feb 10, 2005.
  1. supo
    supo
    Feb 10, 2005
    142
    16
    Please I am very new to this. Can you recommend Good slim av receivers for use with canton CD 1 speakers
    1 It needs to be good with music and movie
    2. Should have 6-channel imput
    3. Needs to be super-slim
    4 Prefarably black
    supee
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    Pioneer VCXS502 is the slimest with 6 channel inputs i know of not sure if available in black (402 its smaller sibling is but no 6 channelins)
  3. supo
    supo
    Feb 10, 2005
    142
    16
    Thanks- But will they go OK with canton cd 1 speakers? What about thye yamaha SL100, are they OK with Canton CD 1 speakers.
    Tha canton sub is rated 100 watts while the satellites are 80watts each. I read somewhere that a higher spec amp is better for a speaker than one which is lower powered-=is this true?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    dont worry about AMP ratings....they are nonsense marketing BS (SUB is active so has its own AMP) loads of people are using 402 and 501/2 with Cantons Panasonic do some silver SLim amps but never heard the Yammy so cant comment....
  5. patr1ck
    patr1ck
    Jun 29, 2002
    247
    Manchester
    +26
    What about the Panasonic SAXR50 or SAXR70 receivers?
    The SAXR70 is available for around £320.
    Not sure if black version available in UK.
    Pat
  6. patr1ck
    patr1ck
    Jun 29, 2002
    247
    Manchester
    +26
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    the old very very SAXR10 does a great job with them in fact i know of a UK shop with the combo on demo.......
  8. supo
    supo
    Feb 10, 2005
    142
    16
    Thanks, but I have already ordered the speakers. I am narrowing my search to Pioneer 501, panasonic sa-xr70, and sony str-lv700r, but its not been easy to make a final decision. I will definitely appreciate advice from experienced people here.
    supee
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,416
    The Borders
    +2,590
    supee
    Best advice would be to find an AV Receiver you like the sound of when partnered with your Canton loudspeakers - if its slim line your troubles are over; if its not hide it away and use an IR extender.
    No matter how good it looks in your room if you cant find a slim line unit that sounds good with your speakers you're not going to enjoy your system.
    Best regards
    Joe
  10. supo
    supo
    Feb 10, 2005
    142
    16
    Unfortunately, I wont be able to test equipment with thye speakers as live in a village without any major HIFI stores
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    the pio 501/2 is where i would put my money
