Please recommend an Ideal screen for a Optoma HD72i
Discussion in 'Projectors, Screens & Video Processors' started by 5slices, Jan 5, 2007.
  1. 5slices
    5slices
    I recently bought a saphire 16:9 90" electric screen which isnt quite upto the task of getting the right image from my projector
    1:1 gain still gives bright spot on lights and whites
    also
    Despite weighting at the bottom, the screen will not go totally flat (which is noticeable when images span across the screen)
    Please recomended a quality (but not too expensive) screen and let me know what you are using as it really is the mssing link in my system to keep me happy
    In the meantime can anyone give advise on making the screen flatter!?!
    thanks
  2. AV Nik
    AV Nik
    Jul 11, 2006
    581
    46
    +100
    Hi 5slices,
    Try leaving the screen down for a few days. If that doesn't work, let the supplier know and I'm sure they will exchange it.
    A good choice of upgrade would be something like the Draper Baronet or Projecta Procinema which have ripple warranties.
    Hope this helps
    Nik
