Please recommend a video scaler £300-£350
Ewoody
for use with Philips 50 inch plasma (1366x768 resolution) DVI-i input.
And SkyHD box.
thanks
ewoody
cutes6
Ewoody,
I would say you can't beat the Lumagen vision DVI, it will do everything you need and do it very well.
The first problem will be finding one for sale the second problem will be getting one at that sort of money.
I have just recently bought one on these forums but the misses is moaning that it has the made the setup too complicated with another remote :eek: :eek: so I might be reselling this great bit of kit :( :(
DarkDogZA
Ewoody,
Can I ask if the Mrs noticed the difference with/without the Lummie ?
choddo2006
Ewoody,
Get a pronto ;)
cutes6
Yes they did notice the difference in picture quality - but hey I just do as I'm told.
I have put the Lumagen up for sale in these forums.
sniffer66
Will the Vision DVI scale 1080i outputs (with HDCP) to 720p happily ?
Im on a limited budget at the mo and Im wondering whether I could get one until I have more cash or I should be looking at a HDP etc for my Sky-HD and HD-DVD
choddo2006
Yes it will scale it but no per-pixel deinterlacing (I guess this means it does a simple bob on 1080i sources). You need the HDP or HDQ for that I believe.
sniffer66
Thanks, in real terms though will that still give a noticeable improvement over the internal scalers in my existing devices or should i hold out for the HDP ?
sniffer66
Ok, a little reading has answered my question. Looks like the HDP at a minimum then.
Time to save some pennies
