Please recommend a TV...
Discussion in 'General TV Discussions Forum' started by adamhamilton, May 30, 2002.
  1. adamhamilton
    adamhamilton
    What's the best TV I can buy at the moment in terms of picture quality. I will probably go for a 32" and will use it for 70% Digital (Sky) TV and 30% DVD.
    I want to be able to use RGB from both the Sky box and my DVD player. I want to be able to manually select the screen size/shape and not be forced to put up with what the TV chooses.
    I'm not bothered about the sound as I will be using my Denon AVR + 5.1 speakers.
    Thanks for your recommendations.
  2. Spunky
    Spunky
    Jan 8, 2002
    113
    19
    Norwich/Liverpool
    Most people will tell you to go for a sony dx100- which doesn't seem to suffer from scrolling bars, or for one of the phillips pixel plus models. Or for a loewe.
    I can recomend the sony its got a great picture , but only nicam stereo- i've got an fq75 luckily not having the infamous bars :rolleyes:
    Your best bet is to get to a show room and judge for yourself. For each t.v. you ask about somone will have a great/terrible opinion of it.
    The choice is yours. :confused:
    Spunky
