Please recommend a Child-proof Hifi Rack
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by Buckster, Aug 3, 2005.
  1. Buckster
    Buckster
    May 21, 2001
    7,247
    103
    UK
    +370
    Hi there - can any one recommend a cheap-ish hifi rack that has safe glass doors so that my Pioneer AV amp (2011) and Toshiba 9500 DVD player can be safe from my toddler please - I'm running out of tape at the moment !! (volume dial taped, selector switch taped etc ....)
    The 2011 is quite large which is causing problems - and ideally also needs to be open backed temperature wise.
    Max budget about 100 pounds - annoyingly I have a decent hifi rack - its just completely open so not child proof.
    Many thanks for any help,
    Mark.
  2. *ChrisB*
    *ChrisB*
    Apr 22, 2005
    310
    Berkshire
    +11
    I've been really lucky that my 4 year old daughter has always understood that it's very bad :nono: to go near my hifi stuff & subsequently she has never touched it :thumbsup: .
    However I was all ready to have a piece of clear perspex cut to the size of the front of my rack which I intended to velcro onto the front of the rack if she started to show an interest.
    It would certainly be alot cheaper than buying a replacement rack & you'd only need to remove the front if changing a cd or dvd.
    Might be completley useless to you but thought I would share :)
  3. AMc
    AMc
    Nov 20, 2000
    6,903
    Near Norwich
    +3,496
  4. britco
    britco
    Sep 24, 2004
    187
    +3
    is there such a thing?
