Please recommend a 46" to 50" TV
Discussion in 'What Is The Best TV For You?' started by pfchiu, Mar 8, 2013.
  1. pfchiu
    pfchiu
    Feb 15, 2005
    9
    Hi All,
    Could you please recommend a 46"-50" that you feel would best fit my requirements.
    Budget: up to £600 (can increase to £700)
    Screen size: 46-50"
    Main Uses: Playstation 3, watching sports, Movies and general TV.
    I have no requirement for Smart TV or 3D functions.
    Thanks in advance.
  2. Scooby2000
    Scooby2000
    Jan 9, 2010
    15,549
    Cambridge
    +2,469
  3. Scooby2000
    Scooby2000
    Jan 9, 2010
    15,549
    Cambridge
    +2,469
    Great retailer, great price, fantastic set.
    http://www.amazon.co.uk/gp/aw/d/B007JUOGKE
    Got my D6900 from Amazon warehouse, was graded as 'like new' it was a brand new set:) very happy with it, fantastic for gaming and will meet your other needs too. Great for the money.
  4. pfchiu
    pfchiu
    Feb 15, 2005
    9
    Would you be able to recommend a smaller alternative please? After looking at the TV's in the shops I'm thinking a 42-46" would be more suitable.
  5. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
    Panasonic 42st50 perhaps
  6. Loopthrough
    Loopthrough
    Jul 27, 2010
    1,562
    116
    UK
    +523
    Sony KDL46HX753. Slightly higher than your budget, but at this size range you really shouldn't skimp - this is a long term investment!
  7. Scooby2000
    Scooby2000
    Jan 9, 2010
    15,549
    Cambridge
    +2,469
    ST50 is worth a look.
    The Sony's a good set but if you need low lag for gaming the ST50 is better. Also sport wise the ST50 is by no means perfect with motion, but you get higher motion resolution and no LCD blur or artifacts related to motion processing. Also consider when you'll be using the set and viewing angles.
  8. ISHANTY
    ISHANTY
    Sep 13, 2002
    560
    3
    28
    UK
    +66
    St50 is very good value
  9. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
  10. pfchiu
    pfchiu
    Feb 15, 2005
    9
    Thanks guys, in your opinions would be worth stretching my budget and consider a 42gt50?
  11. Scooby2000
    Scooby2000
    Jan 9, 2010
    15,549
    Cambridge
    +2,469
    No I'd not stretch yourself, maybe invest some time to find one around the same price but unless you want THX and the extra picture controls Id not bother.
    Also check as Im not sure of hand, both may not have freesat if needed.
