Please reassure me about my Tosh...
Discussion in 'General TV Discussions Forum' started by Timmy O'Toole, Mar 25, 2002.
  1. Timmy O'Toole
    Timmy O'Toole
    Just tried turning on my Tosh 32WD98B using the remote, but nothing happened. The red light remained static.
    Tried the on/off switch. Nothing happened, red light still on.
    Fumbled around the back to try and find the correct power plug. Probably briefly disconnected the power. Noticed now had static red light & green light flashing regularly.
    Tracked the correct power lead, disconnected till lights were off. Reconnected power. Got red light. Tried remote, and everything working. Now tried on & off a few times, and everything seems ok.
    Could this have been caused by a temporary power surge maybe, while I was at work, confusing the circuitary, similar to what you can get with a digibox. Or is it something more sinister. ie something faulty.
    Cheers in advance.
