Please Please Please Help
Discussion in 'Home Cinema Speakers' started by scrapbook, Jun 27, 2002.
  1. scrapbook
    scrapbook
    Jan 12, 2002
    7,436
    +553
    Someone must have some advice I can use!
    I have had a Sony Home Theatre Kit for 6 months now (the slim line amp version - 80w per channel), no idea how good this system is, but it met my needs at the time.
    Anyway I am not convinced the Pascal speakers are much cop, call it a gut instinct - they seem particulary bad on CD music, but not too bad on DD or DTS films.
    THe time has come when I feel a need to upgrade the speakers, what do I go for? I am on a budget and am currently considering the Mission M72 - are these likely to hit the spot for me?
    The speakers I have at the moment have a frequency range of 160hz to 20khz - what does this mean in comparison with the Missions that are 68hz to 20khz?
    What makes a good speaker good? Is it the frequency range? or is that a stoopid question in the first place? And are there any compatibility problems between speakers and amps I should know about?
    THanks for any help!
  2. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Your gut instinct is correct and the Sony Pascal speakers are probably a weak link in your system that can be improved by changing to Missions.
    Frequency Response is one aspect of a speaker but quality of design and engineering plus the components used have a great deal more effect on how a speaker will sound.
    The bottom end of your current speakers, quoted at 160Hz, is too high and I presume that you are using a Sony sub woofer that will extend the frequency range down further.
    A decent speaker should go down to 50Hz or 60Hz with a subwoofer taking care of the sub bass frequencies below that. The Missions will improve the overall sound quality but it won't be long before you start hankering after a decent sub woofer as well.
    Welcome to home cinema
  3. lynx
    lynx
    Jan 20, 2002
    4,652
    It always rains.
    +302
    scrapbook, from the forum guidelines,
    Other post
    Clutters the forum unnecessarily. :)
