Please, please help with Denon 500
Discussion in 'Home Cinema Buying & Building' started by Matt05, Aug 4, 2005.
  1. Matt05
    Matt05
    Feb 16, 2005
    36
    I changed the output to component from the Denon menu and there is no picture on my TV now. I can't seem to get any picture on screen from SVHS now that the output has changed.
    Is there a way to "reset" the denon so i can see the menu on screen?
  2. Conn
    Conn
    Jan 2, 2005
    2,056
    +170
    Try this -
    From power on with no disc in
    >press set up
    >down twice
    >enter
    >down 5 times
    >press enter until (hopefully) your picture comes back
  3. Conn
    Conn
    Jan 2, 2005
    2,056
    +170
    Any good?
  4. Strangerer
    Strangerer
    If you connect the player to the TV using composite (yellow) lead you should still get a picture then chande the settings cack then remove the lead.
