please offer advice on this as a MCE based system
Discussion in 'Microsoft Windows' started by newstuart, Apr 23, 2005.
  1. newstuart
    newstuart
    Apr 22, 2004
    1,797
    Northumberland
    +82
    I have just bought as a project the below spec pc and was hoping for any advice on if i have everything i need for a god MCE based machine ? It will really only be used for mce and storing DVDs on 2 150gb hardrives i intend to buy soon. It will output via VGA to a plasma screen and optical out to a amp/decoder.
    Reliability of the machine being used as my main source of TV and DVDs is my main concern so If you can see where any of the kit may cause issues i would much appreciate your advice.
    The case is an Antec Aria . The mother board is a Gigabyte GA-81G1000MK
    which is fitted with a 2.8Ghz P4 800FSB HT chip with a Coolermster HSF and a single stick of 512Mb of Ram.
    It comes with an ATI 9600SE 8x AGP Graphics card.Maxtor 40Gb Quickview AV hard drive and a LG GSA-4120B DVD Writer Soundblaster Live card which gives DD & DTS surround.
    I have also just bought a The Nvidia NVTV tv card to fit in it.
  2. stuartmc
    stuartmc
    Oct 20, 2004
    203
    16
    Reading
    Looks ok to me. As you identified you'll need a bigger hard disk. Make sure you get the drivers from ATI not the card manufacturer for full MCE compitability. Can't remember the Soundblaster Live! but if you want to output to a 5.1 AMP/Receiver you'll want S/PDF.
