please help!!!
Discussion in 'Plasma TVs Forum' started by satch, Jan 11, 2003.
  1. satch
    satch
    im about to order a pan 5 online, but need to know if i need the terminal board to connect to my sky dig and dvd?
    or is this terminal board only used with the pan tuner???
    :confused:
    thanks.
  2. Rob100
    Rob100
    Nov 3, 2002
    3,482
    +227
    Without any terminal board you will only have a VGA socket and will need an RGB-VGA converter.
    The terminal board for the tuner and the one that gives you RGB/Component and Composite/s-video are different board.
    There are loads of threads all about connecting up a Panny 5, so I suggest you do a search to decide what's best 4 U.
    Rob
