Please Help!!
Discussion in 'LCD & LED LCD TVs Forum' started by ubot, Sep 12, 2007.
Tags:
  1. ubot
    ubot
    Sep 12, 2007
    74
    Hello im looking to buy a new hdtv and have the same problem as i suspect a lot of people have.....Which one!!!!
    Could someone help with their expert knowledge :)
    Ill be using it for
    1. mainly Standard television about 8 hours a day
    2.PS3 about an hour a day
    3.A few DVDs a week
    Would i need a 1080p tv for what im gonna be using it for?
    Ive narrowed my search to these,any one got know more about these tvs?
    Samsung PS-50Q97HD
    SAMSUNG LE46F86BDX
    Samsung le46m86
    Sony w2000
    or should i fork out a bit more for 1 of the pioneers but most of them are ont full hd
    Thats about it
    I hope there someone out there who can help me
  2. nitro23456
    nitro23456
    Jul 30, 2007
    293
    Resident Panasonic LXD70 Expert
    +15
    get a panasonic - they are the best.
    I would avoid samsung as they have many known faults, look waaay to bling and there is also a panel lottery with some models - you don't know which panel you will get, literally.
    you wouldnt need 1080p for your uses and stop watching so much TV - theres a whole world out there!! :)
  3. davejm
    davejm
    Jun 29, 2007
    188
    +15
    The Panasonic 32" may be regarded as the best in it's class, but that's not necessarily true of the larger panels nitro.
    I shortlisted Sony, Samsung, Sharp and Toshiba 37" 1080p TV's when I was looking for mine, and went for the Samsung M87 in the end due to their better input compatibilty and price (cheaper than the Sony).
    If you're careful, you don't have to worry about panel lottery or the firmware issues (check the M86/M87 thread for details). Not sure about the new F8 range though.
    I don't think you'd specifically need 1080p, but you may want to consider it if you want to go for Blu-Ray, HD-DVD or a HTPC at some point in future. If not, you may infact want to look at a Plasma.
  4. ubot
    ubot
    Sep 12, 2007
    74
    Thanks guys
    i also like the samsung m87
    whats the picture like on standard definition tv?
  5. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    not as good as pioneer....
  6. ubot
    ubot
    Sep 12, 2007
    74
    But most pioneers havent got 1080p
    How would a PS3 look on it?
  7. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    I have seen some pics on pio thread with BR and was excellent too...
  8. HRL
    HRL
    Oct 23, 2006
    2,958
    103
    +396
    I've got the 46" M87 and PS3, Blu-Ray and upscaled DVD is absolutely fantastic. :smashin:
    Standard definition TV is awful though. :thumbsdow
    If you're going to be spending most of your time watching SD then go for a non-1080p Plasma instead. They just handle SD better with the lower native resolution.
    1080p is fantastic as long as you're going to be using it. 1080i will do, that's what my SkyHD box outputs.
    HTH
  9. ubot
    ubot
    Sep 12, 2007
    74
    What pioneer do you recommend?
    The 428Xd?
  10. ubot
    ubot
    Sep 12, 2007
    74
    is sd better with sky HD?
  11. HRL
    HRL
    Oct 23, 2006
    2,958
    103
    +396
    SD is SD but the standard Freeview channels seem to be ever so slightly better off of the Sky box.
    I'd only recommend a native 1080p/1080i set if that's what you're primarily going to be using it for.
