please help!!!!!!
Discussion in 'General TV Discussions Forum' started by snake II, Jun 22, 2002.
  1. snake II
    snake II
    May 19, 2002
    353
    luton
    +5
    yeah , i got a bedroom size tv, its a 21'' thompson nicam tv the model number is 21MG17UG i got it from argos. Now what i wanted to know is can i connect a 5.1 surround sound system to this tv, as i have seen on an index catalogue a cheap surround system which can connect to nicam tvs, please help as i would like to connect a 5.1 system (cheap) to my tv so i can experience 5.1 or dpl2 on my gamecube system.
    cheers
  2. Kevo
    Kevo
    Aug 23, 2001
    5,412
    Manchester
    +151
    The question is not whether you can connect a 5.1 system to your TV but to your Gamecube.
    As long as your GC has an audio optical or coaxial output then YES.
  3. snake II
    snake II
    May 19, 2002
    353
    luton
    +5
    my gamecube supports dolby prologic 2 and has s-video support feature, along with rgb scart support
  4. Kevo
    Kevo
    Aug 23, 2001
    5,412
    Manchester
    +151
    I'm not very familiar with the GC but if it doesn't have any of the sockets I mentioned then it won't output DD5.1, only DPL which you can usr the SCART for.
