Please help
Discussion in 'Plasma TVs Forum' started by novice2, Dec 29, 2004.
  1. novice2
    novice2
    :lease: Any help at all for a poor novice??
    I have just purchased the 37 Panny (TH37PE30) and getting the DMR E55 free. What I really want to know is should I use the DMR E55 as my main DVD player or stick to my (old but still good) Toshiba sd 220E as my main player and just use the DMR E55 as a recorder (I will also be using the tosh and/or the DMR E55 as a CD player)?? Also how do I go about setting up all of these boxes. I was thinking:
    1 SKY + to Panny = RGB
    2 SKY + to Receiver (Yamaha 430RDS) = optical
    3 DMR E55 to Panny = RGB
    4 Toshiba to Panny = component
    5 Toshiba to receiver = coaxial
    6 terrestial ariel to the DMR E55
    Would this be the way to set it up? any better way?
    I really need help on this one.....go knows I am confused??
    Will this set up allow me to record from SKY + to the DMR??
    Sorry for all the questions but any advice would be gratefully received.
    Many thanks
  2. novice2
    novice2
    :lease: :lease:
    I know its a pain answering simple questions such as these but i really would appreciate any advice. I have a new toy to play with but don't know how to make it work!
  3. -Jay-
    -Jay-
    Jul 26, 2002
    4,934
    Kop End
    +135
    It's only been 30 mins mate someone will answer soon lol
  4. novice2
    novice2
    unfortunately I am at work (which is the only place I can access tinternet). I fear the pub will call me before too long with the answer to my AV question unanswered. You see my dilema?
  5. jont
    jont
    Apr 8, 2002
    4,244
    near Aylesbury
    +546
    If you want to record from sky+ to the DMR then you will need to hook the two together via scart ... the DMR can then playback 'through' the sky+ should you need ...
    So if you have a rgb scart and component interface for the panny then as you described will be fine ...
    Jon
  6. novice2
    novice2
    Thanks for the suggestion.
    If I am understand (which I fully admit I may not), my set up should be:
    Toshiba SD 220E to Panny = component
    Toshiba SD 220E to receiver = coaxial
    DMR to receiver to panny = RGB
    SKY+ to DMR = RGB
    SKY+ to receiver = optical
    ie no direct hook up between the SKY+ to the panny. Is this right??
    Also, shoul i continue to use the Toshiba or use the DMR as my playback machine?
    Thanx for any help
  7. novice2
    novice2
    Just noticed how often this question is asked. Apologies.
    Still confused... :oops:
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    depends if you want to be recording Sky analogue/Freeview and still be watching a DVD....
    SKY+>E55>AV4 scart and componet and AV4 set to Qlink is the way i set them upt (can keep tosh on RGB for playback as well)
