Please Help!
Discussion in 'Plasma TVs Forum' started by sad1f, Nov 26, 2004.
  1. sad1f
    sad1f
    i have got a panasonic pwd6 plasma with s-video component (bnc) board etc
    and also a yamaha ax750se av amp...
    so i bought (from keene) a bnc to rca component video cable and though i'd "test" the system...
    i plugged the componenet cable from the "monitor out" to the plasma... and i though it's working because the amp's display overlay thing came on... although the picture did seem to be shaky...
    but when i plugged a dvd (via s-video) into the amp or even the xbox (via s-video) nothing came on the screen...
    i even tried putting the xbox into the plasma direct and i got "no signal"
    can anyone suggest something... i was hopeing to have it up and running this weekend...
    many thanks
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,310
    +1,217
    is it the dual slot board you have?
    make sure there is no composite cable connected and Xbox is set to S-video and input is selected to S-video
  3. sad1f
    sad1f
    it is the dual-slot board... i will try those...
    i have just plastered in the power and componenet video cable into my wall... was thinking the worst...
    (the plasma is not up yet, i was just making sure it actually works!
    thanks....
