Please help!
Discussion in 'Plasma TVs' started by ronald, Nov 21, 2004.
  1. ronald
    ronald
    Hi, I set up my new Panasonic Viera plasma last night. It was working OK for about 20 minutes, then I noticed a fine line about halfway up the screen going horizontally across - this was on all stations, both from Sky & the normal aerial. I went out of the room & when I returned the picture was completely scrambled, sound is fine - again on all channels. I cannot bring up the menu screen & the set now turns itself off after a few seconds.
    Obviously I will contact the dealer on Monday, but I don't want to repack it all if it is something simple (I am a complete muppet at this stuff!). Any suggestions gratefully received...........
    Many thanks!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Switch it oiff at the mains leave it 30 min and try again time how long it stays on before going mad... Sounds like a either its getting to hot/PSU issue or video drvie is dying if it is under 7 days old you can have a brand new one not a repair (push for a new unit)
  3. ronald
    ronald
    Thanks for the reply........... I'll contact the dealer tomorrow!
