Please help
Discussion in 'Playstation Forums' started by niall1, Jun 10, 2009.
  1. niall1
    niall1
    Jun 10, 2009
    26
    3
    Hello everywon my name is niall i am 18 and from england
    this is a problem for me
    i have a ps3 80gb
    when online playing call of duty world at war i cannot join my freinds game even if they are private matches it just says game server unavalible or cannot join they cannot join myne and get the same message either it seems to happen to all of them with there mates aswell it has only worked about 3 times can anywon help me ?
  2. BamBamMickey
    BamBamMickey
    May 20, 2009
    6,820
    Dublin
    +1,294
    It's most likey settings on your router.
    You would need to make sure your Nat is open and not strict.
    Also turn off router firewall.
    Failing that you may need to open other ports.
  3. FourthLion
    FourthLion
    Apr 28, 2009
    278
    Brighton/Glasgow/Stratford Upon Avon
    +18
    I had similar problems which were cured by changing my DNS settings, easily searchable to get sensible DNS settings.
    Also had to totally reset my router once when it wouldn't let me play any games at all.
  4. niall1
    niall1
    Jun 10, 2009
    26
    3
    what is the nat? and how do i make it not strict?
    also how do i open other ports?
    thx for help so far
    ps thxjon33c
  5. ThuGLy
    ThuGLy
    Jan 2, 2009
    3,002
    +1,684
    not a good idea to put your e-mail address up bud let them reply via thread or private message you through here :smashin:
    also go thrugh your internet connection test on the ps3 what nat type do you get is upnp available aswell?
  6. niall1
    niall1
    Jun 10, 2009
    26
    3
    everything sucsedded
    upnp is avalable
    Nat = nat type 2
    what should i do?
  7. niall1
    niall1
    Jun 10, 2009
    26
    3
    Anywon?
  8. Ben-H
    Ben-H
    Mar 23, 2009
    3,371
    Solihull
    +1,024
  9. Zeromajor
    Zeromajor
    Feb 9, 2008
    4,419
    Btown
    +594
    Hi Niall welcome to the forums, please try to post in the correct section. There is already a folder for call of duty and network problems :thumbsup:
  10. connor1
    connor1
    Aug 29, 2006
    666
    28
    Brighouse, West Yorkshire
    +64
    Can you tell us what type of router it is? I used to have a few problems with playing games over the same network. I ended up having to update the firmware on my netgear. Also are you able to try another game to see if you can connect to private games on that
  11. niall1
    niall1
    Jun 10, 2009
    26
    3
    bt home hub
    problem may be fixed my mate could join my game as soon as i done the port program
    hes never joined them before i will right back with more results tonight. thanks all
  12. Ben-H
    Ben-H
    Mar 23, 2009
    3,371
    Solihull
    +1,024
    Looks like you've fixed it then if he can join games now! Good work! :smashin:
  13. niall1
    niall1
    Jun 10, 2009
    26
    3
    i am not sure it has worked now i cannot my freinds games and my freinds cant join myne:( so annoying
    always the same message game unavlaible or server down something like that
  14. niall1
    niall1
    Jun 10, 2009
    26
    3
    anymore idears?
  15. HimIndoors
    HimIndoors
    Mar 29, 2008
    958
    43
    +128
    A lot of people dislike the invite system in COD as they get too impatient - if you know the people on your friends list give them a ring and try to work it together. I've always found it is a case of being patient and accepting the invite straight away before they close the lobby.
    I note you have a homehub, I moved away from BT as I found the hub was a problem with a lot of games.
  16. niall1
    niall1
    Jun 10, 2009
    26
    3
    i tried phoneing them
    i can join one of my freinds games and he can join myne but that is all
    i think they could improve on the cod online system with adding freinds apart from that the online is great if u lagg it only crashes you most of the time not the whole game.
  17. Happy Gamer
    Happy Gamer
    Jun 13, 2009
    211
    +19
    Hey bro are you the dude from Youtube that started Trey 4 Life? because if you are i'm your biggest fan!
  18. ThuGLy
    ThuGLy
    Jan 2, 2009
    3,002
    +1,684
    can your Friend that u can connect to join your Friends that u cant connect to games though?
  19. niall1
    niall1
    Jun 10, 2009
    26
    3
    yes he can join theres and they can join his but he is the only one i can add and join to.
  20. ThuGLy
    ThuGLy
    Jan 2, 2009
    3,002
    +1,684
    OK i was in a similar situation a while back and and i used to invite the one that could play with all then once he was in he'd invite everyone else. failing that could your friend not just host the games ?
  21. niall1
    niall1
    Jun 10, 2009
    26
    3
    yes but when he is not on there is 3 or 4 of us not being able to play thats the problem lol
    also we tryied that i invited him then he invited the guys who couldent join and it dident work still it just wouldent work in my server or if he added me to theres maybe i should ask my mates to open there ports?
  22. ThuGLy
    ThuGLy
    Jan 2, 2009
    3,002
    +1,684
    you've made quite a few changes to your router aswell port forwarding etc if its still not working factory reset it(normally a little button somewhere on the router). then run as normal but try it with these servers.
    https://www.opendns.com/start/device/router
  23. ThuGLy
    ThuGLy
    Jan 2, 2009
    3,002
    +1,684
    its a big ask though if theirs are connecting right, i know its frustrating though all you wants a decent game with ya buds!
  24. niall1
    niall1
    Jun 10, 2009
    26
    3
    i dont want to restart my router then it go wrong and not work im not very good with computers and dont want to loose my connection or make things bad is the guide simple and easy and do i need to edit or delete things'?how long would it take also?
  25. ThuGLy
    ThuGLy
    Jan 2, 2009
    3,002
    +1,684
    not a big job prob 20-30 Min's and theres no guarantee itl work if you don't want to do your router try it on the ps3 its self..
    SETTINGS > NETWORK SETTINGS > INERNET CONNECTION SETTINGS > WIRED CONNECTION OR WIRELESS >
    WIRED CONNECTION > CUSTOM > MANUAL SETTINGS > AUTO DETECT > AUTOMATIC > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X
    WIRELESS > ENTER MANUALLY > ( ENTER SSID OR CONTINUE ) > ( CHOOSE SECURITY OR CONTINUE ) > CUSTOM > AUTO > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X
  26. niall1
    niall1
    Jun 10, 2009
    26
    3
    i will try the ps3 now brb
  27. niall1
    niall1
    Jun 10, 2009
    26
    3
    what do i put when it says ip adress settings automatic manual pppoe
  28. niall1
    niall1
    Jun 10, 2009
    26
    3
    i typed in the dns1 and dnds2 but now i cant scroll to anything but backwards what do i do?
  29. ThuGLy
    ThuGLy
    Jan 2, 2009
    3,002
    +1,684
    x to set it in, then press right or start i think
  30. niall1
    niall1
    Jun 10, 2009
    26
    3
    do i need to put in my ip adress and default router? maybe thats why i cant go forwed lol
    i dont no how to get my ip adress and what to put for my default router tho?
