Please help - Yamaha audio Issue
John2021
I hope someone here could help me please. Recently, the sound modes/programs of my Yamaha RX-V577 amplifier started switching automatically between different modes repeatedly. That is, when I select "STRAIGHT" when playing music, the amp automatically and continuously switches to other modes such as Hall in Music, Action Game, Drama, Adventure, 7ch stereo, music video, sports etc.
Please does anyone know how this issue can be fixed? Thank you.
Jester1066
If you haven't already, I'd try a factory reset. If you can save your YPAO calibration to a USB stick. This way you won't have to re-run the calibration.
John2021
Please how do I factory reset? I have tried pressing the power button while holding the straight button but it seems to be trying to update via the USB. I am not sure if this is what it's called factory reset. In addition, I don't have any software/USB stick to update from. Any reason the unit was trying to update from USB? Thanks.
Jester1066
Turn the AVR off at the wall socket. It's trying to update the firmware via a USB drive. Then plug it back in and do the following to reset: (you will need to re-run YPAO after resetting)
1. Set the unit to Standby by pressing the Power button.
2. While holding down the Straight button, press the Power button.
3. SP IMP. 8 Ohm Min (Or 6 ohm) will come up on the Front Panel.
4. Press the RightProgram Arrow button repeatedly until INIT-CANCEL comes up.
5. Press the Straight Button repeatedly until INIT-ALL comes up.
6. Press the Standby button to turn off the receiver.
7. The next time the receiver is powered on, the factory settings will take effect.
Hope this helps! 🙂👌
dante01
I think you mean to hold down the STRAIGHT button as opposed to repeatedly pressing it in point 5?
Jester1066
Possibly, but I copied it from Yamaha manual, so if it is hold there's a typo in the manual! 😂😂
dante01
The ability to restore the receiver to its default state is basically included within the ADVANCED SETUP menu. THis menu can only be accessed via the following:
Once in the ADVANCED settings then you need to navigate down to the option entitled INIT (INITIALISATION). Omce there then select the ALL option and then simply press standby again. Once you restart the AV receiver it will be set back to its factory defaults. Note that this doesn't revert the firmware back to how it was when you first received the AVR though.
If you want to read up on the other options within the ADVANCED settings then you can do so in the owners manually from page 94 onwards:
John2021
Thank you all for your suggestions. I have tried to follow the reset steps multiple times, even before posting here, but it did not work. When I pressed the power button while holding the Straight button, I got REMOTE ID..ID1. Then I pressed/held the Program button to get to INIT...CANCEL but when I pressed the straight button again, I couldn't get INIT...ALL. But when I pressed and hold the straight button momentarily, it showed other programs such as TV FORMAT..PAL, REMOTE ID..ID1, UPDATES..USB etc. Even the program seems to only work when I pressed and hold it, instead of just pressing it. It looks like the Program and Straight buttons are not working. Not sure what next to do.
Joe Fernand
AVForums Sponsor
Have you tried taking the batteries out of your Remote control?
Could be a stuck button!
Joe
dante01
Joe
You cannot invoke the ADVANCED SETTINGS and navigate them using the remote. He's oressing the buttons on the front of the AVT itself and this is the only way to access the ADVANCED SETTINGS.
John2021
Yes, I pressed the buttons on the amp itself.
Podcast: Hisense A7G, Zidoo Z1000 & Kudos Cardea C10 Reviews + Movie News and Reviews
