Please help xbox live problem =[[
Discussion in 'Xbox Forums' started by Mikosheart, Sep 21, 2007.
  1. Mikosheart
    Mikosheart
    okay i have a pc downstairs which is using my modem to connect to internet
    Upstairs i have a packard bell pc running a belkin wireless adaptor, i have plugged my ethernet cable into the back of the upstairs pc to try accessing xbox live but
    i get to the ip address bit on testing xbox live and it fails??!!!
    Any help is much appreciated
  2. Brummy1875
    Brummy1875
    Dec 28, 2006
    2,307
    3
    +222
    try rebooting the modem and router to renew the ip adress
  3. t1m103
    t1m103
    Jun 29, 2005
    1,856
    essex
    +191
    on the screen where its failing go to bottom left where it says edit settings,in there scroll down to wireless mode,in there you will see a list of wireless routers the xbox is pickin up ,see if you can see your router,if so select it and retry the tests.
  4. Mikosheart
    Mikosheart
    thanks dude tried that seems to have done nothing
    this is so gutting i wanna get back on gears =[[
    (not been on since i moved house)
  5. Mikosheart
    Mikosheart
    okay done that t1m this is what happened
    i am in edit settings got ip settings then another box DNs settings then a greyed out box which is wireless mode
    what should i do??
  6. Mikosheart
    Mikosheart
    anyone????
  7. t1m103
    t1m103
    Jun 29, 2005
    1,856
    essex
    +191
    check your wireless dongle thing is plugged in correctly to the xbox,has this xbox ever been on live(i had a similar probem when first trying to set up xbox live,it wasnt until ive connected to live via the wired method that it would then let me select the wireless screen,think it might do some sort of update,not sure).are your pc's seeing and connecting ok to the wireless router wirelessly?.
  8. Mikosheart
    Mikosheart
    again cheers for sticking with this t1m
    i dont actually have the wireless adaptor for the 360.
    i am just using ethernet from 360 to my pc
  9. t1m103
    t1m103
    Jun 29, 2005
    1,856
    essex
    +191
    ha ,ok you want to network the pc and xbox360 together.unfortunatly ive never done this way of connecting so if you ask again in the xbox 360 forums im sure someone will be useing this method.
