Please Help !!! With My Sony Tv !!!
Discussion in 'General TV Discussions Forum' started by lee1, Feb 16, 2005.
  1. lee1
    lee1
    Hi can you guys please help me with my sony tv model kp44dx2
    its a rear projection one , i can not seem to change the settings for wide screen and screen display settings
    i purchased it as a display model , and it has always been stuck on where i miss half the picture, and have been messing around with the remote and cant seem to change it ? can someone please please help me and tell me how to ? what do i press on the remote ?
    the remote i have is model rm-y1101
    please any help would be so greatfull.
    thanks
    Lee.
  2. kourosh
    kourosh
    Feb 6, 2005
    14,966
    Portsmouth
    +1,124
    if u look towards the top of the remote the image will be a screen with a couple of lines goin through it vertically and horizontally just keep pushing till u want right screen
  3. lee1
    lee1
    hi thanks for the reply. i have done that but nothing happens ????
  4. kourosh
    kourosh
    Feb 6, 2005
    14,966
    Portsmouth
    +1,124
    the only other thing i can say is mate incase that button on the remote might be faulty try this take the batts out of the remote then press and hold the no 1 button for about 15 secs this resets the remote if that dont work ge in touch with where you bought it from :smashin:
  5. lee1
    lee1
    thanks so much il try that.
  6. lee1
    lee1
    nothing changes ?
    do you thinkiv got the wrong remote for the tv ?
    the seriel numbers are on the top here.
  7. kourosh
    kourosh
    Feb 6, 2005
    14,966
    Portsmouth
    +1,124
    it shouldnt be the wrong remote cause most of the sony tv's are the same (i work in a sony centre)see if u can try it on another tv maybe go in the store where you got it from then u would know for sure if its the tv or remote
