please help with intermitent fault!!!!!
Discussion in 'Xbox Forums' started by seka1980, Dec 28, 2006.
  1. seka1980
    seka1980
    Mar 15, 2005
    125
    +12
    can any one tell me if a 360 will only start up if its conected to a tv
    as ive had my xbox for 9 months now and everytime i start it up i get the 3 red lights,
    at first i thought it was because ive got my 360 going through an av amp into a projector and the signal was not geting through, so i switched between imputs on the amp and reset the 360 a few time it always started.
    after getting fed up of this ive pluged my 360 into a panny 32lxd60, set the lcd to component and started it up and yet again i got the 3 redlights, i finaly got the console to start by switching between the inputs on the tv,
    can anyone please give me any idea as to whats happening?
  2. GMC79
    GMC79
    Apr 1, 2006
    10,641
    Glasgow
    +3,177
    Not quite sure whats going on here, if the connection at the 360 end is not quite right u will get the red lights saying so, but if all well there and not connected at TV end then the 360 will start as normal.
    Bit strange what ur getting.
  3. seka1980
    seka1980
    Mar 15, 2005
    125
    +12
    sounds like my 360 is going back to ms
    it did it ever since i bought it, then after the 1st update was ok
    then i get the feeling the seconed update messed it up again!!!
  4. GMC79
    GMC79
    Apr 1, 2006
    10,641
    Glasgow
    +3,177
    Depending on where u got it would be easier to whip it back to em asap?, Exchanges are pretty fuss free as they only swap consoles not full package. returned my first 360 to GAME nxt day easy.
    Give it one last final check of all cables and get it ready for return.
