Please help with chapter deletion on Toshiba RDXS32
Discussion in 'Blu-ray & DVD Players & Recorders' started by Lex, May 21, 2005.
  1. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Guys,
    I am just about ready to scream and throw things! :mad:
    I just spent the last few hours transferring some DV footage onto my Toshiba RDXS32 and then editing it all into the right order by creating a Playlist...
    However :mad: :mad:
    I just went to burn the playlist to DVD and it wont let me as there are apparently too many chapters! I only read it in the small print afterwards that you cannot have more than 99 chapters per title!
    The joke is I don't need all those chapters (they were automatically created when I transferred the footage via I-link)
    So is there any way I can remove all the chapter breaks without having to re-edit the whole :censored: thing? I wouldn't care if there weren't any chapters at all to be honest as long as I can transfer it to DVD and haven't just wasted my day!! :(
    :lease:
  2. trampas
    trampas
    See the manual - page 94 - on merging chapters. If you merge a chapter with the previous/next you are deleting the chapter break! You could merge all of the chapters if you want to.
    Of course I am not sure what this will do to the Playlist ...
    Good luck!
  3. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Great! Thanks very much trampas. I will go and give it a go... :smashin:
  4. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    That worked perfectly. There was a 'merge all chapters' command. I thought that it must be possible, but I couldn't find it anywhere in the instructions - I find that manual really hard to navigate! :(
    Thanks again.
