Please Help Wire My Speakers
Discussion in 'Home Cinema Speakers' started by humax66, Feb 2, 2009.
  1. humax66
    humax66
    Aug 9, 2006
    64
    Hi Guys.
    Let me say first off that i know very little about HiFi speakers. So here is my problem. i have a pair of Mission Speakers. On the back it says HF and LF. I also got some cable with them. It says SonicLink Aero Space. 200x2 BiWire. Now could someone please tell me how i wire this up to my Amp please. Do i just plug the red ends in to the red sockets on the speakers and the same with the black ones ? if that's right i take it i just put the twisted wires to my amp.
    Thanks Guys
    PS. the links are to Pictures to my Cable and Speakers
    http://i443.photobucket.com/albums/qq154/humax2/P1000894.jpg
    http://i443.photobucket.com/albums/qq154/humax2/P1000885.jpg
  2. StevieBuck
    StevieBuck
    Jul 7, 2007
    3,728
    Aberdeen
    +674
    Pretty much spot on with that yes - just make sure when you put the other ends into the amp that they also match up with the correct colours (black to black, red to red).
  3. Showoff
    Showoff
    Dec 15, 2008
    3,501
    +3,237
    HF = High Frequency (Tweeter)
    LF = Low Frequency (Driver)
    Basically yes, but I'd be a little worried using cable that looks like it's been bodged together with tape. :eek:
    Bi-Wire its commonly thought doesn't add much if anything, you could just as easily put one cable to either side and bridge the other (black to black & red to red) like the top two on my MA's (see pic). Hope this helps.
    [​IMG]
  4. humax66
    humax66
    Aug 9, 2006
    64
    Thanks for the help so far guys. The tape that was on there i did take it off to have a look. I think it was just put on there to mark it as - and + so you know were to put the wires to the Amp. The speakers also come with 4 short strips of copper or brass wire. Not sure what there for ? Guys why is this cable so thick ? Last time i put some speakers in the wire on them was like bell wire. Is there any other cable i could use that is thinner than this. I do live near a richer sounds and a Maplins. Or is this cable very good stuff and maybe i should keep it.
    Thanks Again
    :thumbsup:
  5. Showoff
    Showoff
    Dec 15, 2008
    3,501
    +3,237
    Thicker cable is usually better quality (higher gauge) so as long as its not split anywhere I'd keep it. The copper strips would replace where I have used an extra piece of speaker wire to bridge the terminals (instead of Bi-Wire) you don't need to do both.
  6. humax66
    humax66
    Aug 9, 2006
    64
    Just been working out the cable length. It looks like one of the cables will be to short. Would there be any problem chopping a few feet from one cable and joining it to the other one.
  7. Mark.Yudkin
    Mark.Yudkin
    Sep 19, 2007
    10,043
    Zurich, CH
    +1,542
    No problem. Just solder and isolate.
  8. humax66
    humax66
    Aug 9, 2006
    64
    Thanks for all the help guys. Going to get them wired up tonight. Is it ok to twist the wires together first. Then solder them.
    :thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:
  9. Showoff
    Showoff
    Dec 15, 2008
    3,501
    +3,237
    Yep.
  10. humax66
    humax66
    Aug 9, 2006
    64
    Thanks Guys
    :clap::clap::clap:
