Please Help - Will Sony DAV S550 play DVD -RW Discs
Discussion in 'Blu-ray & DVD Players & Recorders' started by Colin 28, Jan 19, 2005.
  1. Colin 28
    Colin 28
    Jan 18, 2005
    49
    Already made one mistake in ordering Panny E85, until I realised that Sony DAV S550 would only play DVD-R discs which meant I would be throwing away loads of discs after one use. Intend to order Tosh RDX S32 now, but need to know that Sony will play rewriteable discs before I go ahead.
    Can anyone confirm or offer other advice.
  2. mjcairney
    mjcairney
    Oct 26, 2003
    7,135
    2
    2
    137
    Airdrie, Scotland
    +986
    Best thing is to take a disk to a local supplier's shop and ask to try it - that way, you will know for sure.
    Cheers,
    Martin.
  3. Colin 28
    Colin 28
    Jan 18, 2005
    49
    :lease:
    Thanks for suggestion, but I don't have any discs and the DAV S550 has been discontinued. Can anyone elso out there give any help.
  4. mjcairney
    mjcairney
    Oct 26, 2003
    7,135
    2
    2
    137
    Airdrie, Scotland
    +986
    Okay - Let's see if I can offer any help - if you could get access to a DAV S550 anywhere, I'll record something on to a -RW disk and send it you so you could try it - only thing is you'd need to let me know whether you wanted it formatted in VR or Video mode and, of course, I would appreciate if you returned the disk when you had completed your trials - I have lots of -R disks but only a few -RW ones.
    If this suits you, please let me know and also where to post the disk to.
    Cheers,
    Martin.
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    Well with a quick look Here shows that the DAV S550 can play all 4 of the DVD recordable disks.
    Mark.
  6. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    I have the DAVC 770 - which is just the multidisk changer version of the 550 and it plays -R / -RW and +RW fine (+R untested by me but I'm sure that would work).
  7. Colin 28
    Colin 28
    Jan 18, 2005
    49
    :thumbsup: Excellent, sounds like a winner. Thanks.
