Please help! Which TV?
robloxian
Hi, I'm struggling to decide on a new TV. I have until midnight when the 10% eBay code ends!
I currently have this TV:
I'm swaying between these two:
There's about £70 difference between them, with the Sony being the more expensive one.
I'd be using it for gaming - PS4, PS5 (not bothered about the 2.1 HDMI right now) and Sky Q and Blu-Ray.
My budget is £400 but would stretch to the Sony if it's worth it. The Sony ones does say 100hz refresh rate, which I thought was good as they're usually 50hz?
Would appreciate your help.
pastrybloke19
I
I would say neither:
Check out this guide:
work out if you need IPS (wide viewing angle) or VA (better blacks, narrow viewing angle), and look a the low tiers (to fit your budget). If you want value, the hisense models are very good.
robloxian
I
Really? I thought Hisense were a poor model?
pastrybloke19
I bought a hisense model for a friend; he needed a cheap, capable TV - and has been pleased ever since. If you pick the right one and have realistic expectations, then I think they are a good option.
No matter which tv you buy, always get an extended warranty for peace of mind (I.e John Lewis or Richer Sounds).
