Please help, what LCD PJ do I get
Discussion in 'Projectors, Screens & Video Processors' started by apocklington, Jun 22, 2002.
  1. apocklington
    apocklington
    Aug 19, 2001
    38
    11
    Canvey Island Essex
    Hi all.
    I am thinking of getting an LCD PJ, but my problem is this, I want to mount it on the rear wall which is 13 feet from where the screen would be. The screen size I would like would be 6 foot wide and a 16:9 ratio. Is there a PJ able to project a 6 foot widescreen image from 13 feet away. Also I would like to hook it up to an HCPC. TIA.:D
  2. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    The Philips Monroe would work well with that throw distance. Quiet, long lamp life and it also has special widescreen modes that makes it work like a widescreen telly (16:9, zoom, small 4:3). Works with HTPC too!
    The Sanyo PLV30 would also work at 13ft throw.
    Regards
