please help to choose....
Discussion in 'AV Receivers & Amplifiers' started by vysniukas, Mar 4, 2005.
  1. vysniukas
    vysniukas
    Hello, I’m new here. It’s a very good forum!!! I’ve found tons of info here, but now totally confused :suicide: So maybe you could help me and tell me your thoughts about the systems I have on my list.. It will be used for 60/40 music/movies and at the moment I have Jamo E6 speakers set. So:
    DVD:
    Yamaha S550
    Yamaha SL100
    H/K DVD22
    Marantz DV4500
    AV Receiver:
    Yamaha RX-V650
    Yamaha RX-V750
    H/K AVR230
    Marantz SR5500
    Yamaha is cheaper; H/K & Marantz are at the same price range.
    Thanks in advance.
  2. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    With your music preference higher than your movie preference I'd opt for the all Marantz system there, or the DV4500 at the very least and the Yamaha 750.
  3. Tejstar
    Tejstar
    Dec 4, 2002
    23,016
    London
    +1,152
    How much are you looking to spend overall?
  4. vysniukas
    vysniukas
    Here where I located (Lithuania), marantz & h/k costs (converted to GBP) DVD ~200GBP Receiver ~460GBP, Yamaha cheaper a bit
