Please help to choose a stereo amp!
Discussion in 'Hi-Fi Stereo Speakers' started by deardai, Dec 30, 2006.
  1. deardai
    deardai
    Aug 15, 2005
    174
    +6
    Hi guys!
    I'm just about to invest in the JBL-E80 speakers. Could you please recommend a suitable amplifier for them. My budget is £200-£250.
    I've heard that the amp should be more powerfull than the speakers, but those seemed to be quite expensive. Any advice appreciated.
    Regards
    Dai
  2. deardai
    deardai
    Aug 15, 2005
    174
    +6
    anyone?:(
  3. miceri
    miceri
    Apr 8, 2006
    1,048
    Stockholm
    +59
    With that budget, try looking at:
    Cambridge Audio
    Rotel
    They should have somehting in their line ups to cover your needs (system & financally).
    However, with a 'limited' budget, looking for good stereo reproduction (as we all are...), then I strongly suggest looking at 2nd hand gear... Many bargains to be had, and if you are not sure about the suitability regarding the rest of you setup, the seller is generally more than happy to answer questions. Ar ask again here if you think you see a bargain.
