Please help Sky + HD and i Want a Sky + Multi room
watsontotty
Hi Guys,
Just a quick question about my sky, i have sky + hd and a multi-rooms subscription with a standard sky box. I want to replace the standard box with a + box ? can this be done and can i do it myself and how.
I took the option of a self fit with the sky + hd box to replace my standard sky +. But the multi room connection only has one cable but sky + need 2 so can it be done and how and will the sky + box work in the same way as my downstairs box or do i need to pay extra money.
logiciel
The only thing you can't do with one cable, compared to two, is record a channel while you're watching another.
watsontotty
So i can connect the sky plus box and record one programme while watching it, as long as i can record a programme that's fine as i wont need to watch a programme while recording another.
Miss Chief
This is one of the reasons I don't recommend a self install! With Multiroom you'd probably have got your install for £30 or even free and the installer would have run an extra cable for you.
logiciel
Podcast: Reported HDMI 2.1 bugs, Audiolab Amp & LG LED Projector reviews + Best of the Month
