  • Black Friday Deals
    Visit our Black Friday page for our frequently updated, hand picked deals on TVs and other tech.
Please help Sim card problem
Julio V
Dear every body,
Please help me to sort out the problem.
I have just signed a 1 year contract( pay monthly) with O2 net work. What I would like to do is: put the O2 sim card (with 600mins free per month) into a unlock mobile phone. The reason is I will resale the new mobile phone which was supplied by O2.
My O2 phone is : Motorola V3i D&G
My old unlock phone is : Nokia 3310
There is no problem when using O2 sim card with Motorolar V3i
Note:
It seems to me that my Motorolar V3i D&G is an unlock phone. Having inserted a T-moble sim card into it, I found that I could make and receive a call normally.
When inserting my O2 simcard ( with 600mins free) into my unlock Nokia 3310, I was asked PIN code
Any one suffered the same as my problem. Is there any solution for that.
I am looking forward to your advice
cracker
PIN code is specific to the sim card not the phone
so when you got your sim card from O2, they should have told you what the PIN code was for that sim card
if you enter it wrong 3 times, it will lock the sim and ask for a PUK (pin unlock) code, you can get this for free from the O2 website in the help section so dont worry
Julio V
Thanks for your advice. However, I would like to point out that I did know the PIN CODE of simcard : "5555"
The O2 simcard (600mins free) has NO PROBLEM with Motorolar V3i
But it get problem with my unlock Nokia 3310
cracker
you sure it is asking for a PIN code? and not a restriction code?
easiest way to solve the problem, put the O2 sim in your motorola, and go into the menu and turn off the "pin code request" function so it doesnt ask for a pin code at phone startup (im not sure where this option is on a motorola phone)
that way you will be able to tell if the problem is with the sim/pin or the phone not accepting the sim itself
Julio V
Dear Cracker,
I tried to OFF the SIM PIN but the problem still remains
Putting the O2 sim card into Nokia 3310, it said that " Sim Card is not accepted" in stead of " enter PIN CODE"
I think O2 force me to use the Motorolar V3i (they gave me) with their O2 sim card in order to get 600mins free. Is it true?!?!?
Any idea , please help:lease:
cracker
there is no reason why your O2 sim shouldnt work in a properly unlocked phone, they cant force you to use the V3
"Sim Card is not accepted" means your phone isnt open to O2 network sims
is the 3310 dual-band? if it is, then your phone obviously isnt unlocked as you think it is
try going to: http://unlock.nokiafree.org/ and unlocking your phone properly
if the 3310 isnt a dualband phone, then O2 is obviously on a different band to the band the phone was supplied on
Julio V
Dear Cracker,
Thank you very much for your help,
Without your knowledge, I will not make any head or tail about the phone. I put my O2 sim card to my another Nokia: Nokia 7110. It worked. I can see the display: BT cellnet ....How ever My Nokia 7110 has another problem ( not by the sim card) . 7110 can receive calls, can make calls but when it receives a call, you can hear the phone ring, press answer key then you can not hear the caller. It also happened when you call somebody.
I think it has barring code or somthing like this.
I will post my thread to othe subject , calling for help
If you know how to fix it , please let me know. I tried to set the phone to Default Manufactory. *#7780# but it did not work
