please help sanyo z3 and panny s97
Discussion in 'Projectors, Screens & Video Processors' started by andya, Jan 16, 2005.
  1. andya
    andya
    Oct 25, 2002
    2,391
    48
    manchester
    +26
    borrowed my mates panny dvd player to hook up to the z3 projector ,he forgot the remote control i tried using qed component cables but the picture i get is in black and white ,can anyone help the dvds i had were crouching tiger pal and finding nemo pal.do i need the remote to tell the panny its in component ,it all set up ok on the z3
  2. summat
    summat
    Dec 16, 2004
    90
    Preston
    Might be talking out of my arse here, but if you're getting any image from a component-wired setup I'd suggest the Z3 has selected the correct source (if it's anything like the Z2, anyway). Sounds more like a cabling issue (check your green and blues!)
