please help sagem hd56 lens needed..
jester68
hi, i'm new to forum, i have a sagem axium hd56 tv..i need the lens that fits directly behind colour wheel..many thanks gez
Curly99
Hi, welcome to the forum any wanted item ad's should go in the correct classified forum though you could re-word your post so it doesn't read like an ad, such-as
Does anyone know where I can get a lens that fits directly behind the colour wheel of a sagem axium hd56 tv?
Curly
mrfluffy
Which lens do you mean? Behind the color wheel is a long tube that is filled with mirrors, then a lens, then a mirror, then a prism block. Can you take a photo and indicate which part you need?
mrfluffy
Just checked my dlp unit, and the lens immediately after the light tunnel is only about 18mm wide, so it must be a different model. I remember seeing a larger lens in a dlp unit from a HTD501, but I've no idea what exact size it was. Sorry I can't be of more assistance.
