Please Help - PS3 HDMI not working
Discussion in 'Playstation Forums' started by anw13, Feb 5, 2009.
  1. anw13
    anw13
    Feb 3, 2009
    1,134
    38
    +17
    Hi, bought a second hand ps3 on ebay, arrived today. AV standard cables is oworking fine but when i try it on hdmi only sound comes up and it goes to a white screen. why is this? im using the same hdmi cable i bought from argos which worked perfectly for xbox 360. is the ps3 borken or am i doing somehting wrong? thank you
    MOD can you please change to PS3 in title. thnak you
  2. anw13
    anw13
    Feb 3, 2009
    1,134
    38
    +17
    pleaseeeeee someone
  3. Sephiroth0000
    Sephiroth0000
    Dec 25, 2007
    1,054
    Hornchurch
    +81
    Hmmm did you reset the display on the PS3 (turn PS3 on and keep finger on power button until it powers off keeping finger on button at all times. Power it up again keeping finger still on button and it will double beep and shut down again) after it has done this plug in the HDMI cable and power up PS3 as usual. If this does not work then possibly try updating to the latest firmware
  4. andy1249
    andy1249
    May 7, 2006
    8,606
    +2,654
    Theres no need for all that ....simply hold the power button down on turning on for about 10 seconds and the setup screen comes on , thats all you have to do.
  5. anw13
    anw13
    Feb 3, 2009
    1,134
    38
    +17
    AHH thank you so much guys, working now:D:thumbsup:. It asked me if i wanted 1080i? i selected no as wasnt sure. My tv is HD ready not FULL HD. what was best option? thanks
  6. anw13
    anw13
    Feb 3, 2009
    1,134
    38
    +17
  7. andy1249
    andy1249
    May 7, 2006
    8,606
    +2,654
    It will have used the EDID line on the HDMI cable to ask your TV what is the maximum resolution signal it could take , which must have been 1080i , in most cases , this works fine.
    You could always try both and see what works best for you , 720p or 1080i.
  8. Zeromajor
    Zeromajor
    Feb 9, 2008
    4,419
    Btown
    +594
    Changed thread title :thumbsup:
    720p will perform better for you (most games are 720p native) than 1080i so I suggest you use this.
  9. anw13
    anw13
    Feb 3, 2009
    1,134
    38
    +17
    :D all working now thanks guys
