Please help Plasma arrived lying down in delivery truck????
Discussion in 'Plasma TVs Forum' started by Geoxis, Sep 10, 2005.
  1. Geoxis
    Geoxis
    Apr 4, 2005
    321
    Surrey
    +15
    Hello,
    I just received my plasma screen today, and I always thought that they should be transported straight up....... This morning when the truck came with my plasma it was lying down in the truck :eek: . is that bad? Is there anything that I should do before to plug it??????
    Please help guys as I have the telly unpacked and do not know what to do.....
  2. Daipac
    Daipac
    Apr 12, 2005
    659
    +12
    I am with you on this becuase I always thought the same that a plasma should be transported in the upright position.
    Not sure why this is ? Is it to protect the glass ?
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    It's because the glass flexes when the truck goes over a bump, and it can crack the screen. If the screen hasn't cracked, you don't need to worry, but check it carefully, both the glass and the plastic safety screen.
  4. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    So which fantastic company did you order your screen with?
    I'll be sure to give them a miss!
  5. Not A Clue
    Not A Clue
    Don't worry about it - when you wall mount the plasma you have to put it face down (screen to the floor) on the floor anyhow
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,909
    The Borders
    +3,126
    Hello all
    Not a Clue - I guess you have never had the dubious experience of being in the back of a delivery van :)
    Laying a Display down to install video boards, wall mount fixings etc is one thing - rattling around in the back of a non air suspended delivery van is another matter.
    I've seen lots of Display delivered flat and about 90% of them arrive intact - the other 10% suffer from cracks in the Plasma cell layer so you have a display that 'looks' OK on a quick visual inspection but look below the front surface (most displays other than the Pioneer XDE's have a protective front filter) and you'll see the actual pixel layer is trashed.
    What to do when a courier delivers a Display on its back or front is something you need to discuss with your supplier before the kit arrives - I've found that no matter if you note on the delivery slip that the Display was delivered Flat you have no comeback with the courier company if you accept delivery; its often best to simply refuse delivery if you cant get through to your supplier on the phone whilst the courier is still at your house.
    Then again I find it better (though more costly) to simply avoid using 'couriers' these days - its been a long time since we entrusted a Display to anyone other than a trained delivery driver with the correct vehicle and strapping systems.
    Best regards
    Joe
    PS Geoxis - if your unsure what to do next call your supplier for guidance!
  7. Not A Clue
    Not A Clue
    Sales pitch :rotfl:
  8. av2diefor
    av2diefor
    No not sales pitch, the man is a gent.
    And hes helped hundreds of people to boot :)
  9. athina
    athina
    Keep us updated as I am ready to order from NOMATICA a Philips 37PF9830 for 3150 euros and I'm a little worried.
    I suppose these things are insured.....so what happens if the courier breaks it and you discover after you hook it up?. NOMATICA advised that I should return it for replacement immediatly.
  10. da walrus
    da walrus
    Oct 9, 2004
    271
    +10
    had they used to fit a tamper proof 'spirit level' to these boxes some time ago - and you were expected to reject delivery had the level triggered - thereby showing that they had been transproted, incorrectly, ie horizontally?
    good luck in sorting it out.
  11. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,909
    The Borders
    +3,126
    Hello Not a Clue
    Here's what happens if your own of the unlucky ones - http://www.avforums.com/forums/showthread.php?t=180865&highlight=delivered+flat
    As per my previous message if your having a Display delivered to you via a Courier ask your Supplier what Inspection/Delivery process you need to go through BEFORE the goods arrive.
    We have a small 'collection' of Displays that various couriers trashed before they ever got near anyone's front door.
    Tilt meters are a good idea - as it 'bulking' out the packaging around the Displays outer carton to try and ensure it cant fall over or be laid on its front or back.
    Mostly problems occur when the Displays start to get transhipped from one van to the next through a couriers 'network' - I'm amazed at how few courier companies actually supply drivers with decent straps for tying kit to the side walls of their vans.
    Best regards
    Joe
  12. Lionheart
    Lionheart
    Makes u wonder how many problems stem from bad transportation
  13. Geoxis
    Geoxis
    Apr 4, 2005
    321
    Surrey
    +15
    hello guys,
    I have checked carefully and it has nothing..... But anyway I have put on the delivery note htat it was delivered flat and that I did not receive the panel in good condition aha ha ha ah ah........
    So if anything arrives in the next 28 days I could go back to them to say it was because of the delivery :D
    But thanks anyway for all this help,
    Geoxis
  14. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,909
    The Borders
    +3,126
    Hello Geoxis
    It sounds like your couriers got away with it this time - they generally arrive intact or trashed.
    Best regards
    Joe
  15. Not A Clue
    Not A Clue
    Glad to hear it - providing they are not dropped or bounced around they should be ok :)
