Please Help panny th-42pwd6 to a sony dav-sr2
Discussion in 'Home Cinema Buying & Building' started by SANDFORTH, Mar 17, 2005.
  1. SANDFORTH
    SANDFORTH
    Mar 17, 2005
    5
    I HAVE JUST PURCHASED A PANASONIC TH-42PWD6 AND A SONY DAVSR2 I ALSO HAVE A BOG STANDARD SKY BOX MY PROBLEM IS CONNECTING THE PICTURE FROM BOTH THE DAV AND THE SKY BOX INTO THE PLASMA .
    THE DAV HASE ONLY ONE SCART OUT AND THE PLASMA NONE .THE S-VID OVERIDES EVERYTHING I TRY TO DO . :lease:
  2. thewul
    thewul
    Oct 1, 2004
    275
    +15
    s-video has no auto switching so it should not over ride your plasma
    if the plasma has no scart inputs you either need a switching box or a converter to input component
