Please help! NTSC games problem
Discussion in 'Nintendo Forums' started by mmierzwinski, Apr 19, 2005.
  1. mmierzwinski
    mmierzwinski
    Hello,
    recently I bought 32' widescreen Philips Pixel Plus 2 TV. NTSC games do not work on it! I have got PS2 with Ripper 2 mod-chip, RGB cable and... - juest black screen, sound is OK. PAL games are OK. Earlier I used older Philips and NTSC games worked. Please, tell me what I can do?
    Thanks in advance!
    Maciek
  2. Pooon
    Pooon
    Dec 26, 2002
    7,344
    Canterbury, Kent
    +935
    NTSC games should work fine on that set. only thing i can sugest is to try each of the scarts socets on the tv(4?) and check all the menu settings to see if there is an option to disable ntsc and if there is enable it.
  3. mmierzwinski
    mmierzwinski
    unfortunately, TV has not... I tried everything.
    maybe I can switch PS2 somehow?
